C2 Radiator mount shim finish - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3158
    The body mount shims under the radiator support are welded in on my 67. Should these then be painted black as the frame is, or would they be cad/zinc plated with weld marks exposed? Were these welded shims possibly hand sprayed before the body drop? The remainder of the shims are natural.
    Steve
  • Roy D.
    Infrequent User
    • March 1, 1980
    • 2
    Re: C2 Radiator mount shim finish
    The same condition exists on my 65 coupe. I always assumed that the welded shims were placed there by a former owner and subsequently painted in a prior restoration.
    • Stephen L.
      • May 31, 1984
      • 3158
      Roy, I have read in some corvette manuals they were sometimes welded in place.....Were yours also painted?
      • Roy D.
        Infrequent User
        • March 1, 1980
        • 2
        Yes
        • Ray C.
          • June 30, 2001
          • 1132
          Hi!
          On page # 143 of the 1965 Gudging Guide, body mount shims. Front frame horns typically used welded-on-unplated, cadmium, or zink plated shims.
          Hope this helps!
          Ray
          65 250HP & 61 270HP
          Ray Carney
          1961 Sateen Silver 270-HP
          1961 Fawn Beige 315-HP
