C2 Speaker - NCRS Discussion Boards
C2 Speaker
  • Dan White
    C2 Speaker
    The speaker in my 66 sounds terrible, and I think it is blown. I have been looking at the dual speaker replacements that are offered by Mid America, as well as others, but noticed only repo speakers have a transformer. What is the reason for this transformer, and is it required for operation? Thanks in advance, Dan
    • 43221
    Re: C2 Speaker
    Dan------
    1963-76 Corvette radios require speakers with a 10 ohm imdedence. I don't think that speakers with this rating are manufactured anymore. So, I'm guessing that what you describe as a "transformer" may be a device to impedence-match a current speaker to the 10 ohm requirement of the Corvette radios. But, it's just a guess.
    • Dan White
      Re: C2 Speaker
      Would a speaker with less than 10 ohms impedance work at all, or will something get damaged if I try this. I think most new speakers are around 4 ohms. Thanks, Dan
        • 43221
        Re: C2 Speaker
        Dan-----
        Yes, most modern speakers are 4 ohms impedence. You can't use a 4 ohm speaker without risking damage to the radio. Plus, it will sound terrible; I've been down this road once-upon-a-time. However, if you can find an 8 ohm speaker, and there are some out there, they will work acceptably as-is.
        • Joe C.
          • August 31, 1999
          • 4598
          Re: C2 Speaker
          Dan:
          If the paper cone is intact (not torn), then your speaker is not blown. These are old radios, and do not have the fidelity of modern units--they all sound terrible (by today's standards). The original speaker had the transformer, and replacements are available as original. I bought mine from L.I. Corvette Supply.
          Joe
