1960 Courtesy Light Switches - one or two? - NCRS Discussion Boards
  • Rick Coleman
    My 60 currently only has a Courtesy Light switch on the drivers side. The passenger side has the wiring, but no switch. If there was ever one there, the mounting hole has been filled and painted over.
    Was there a version/option that provided for only one switch?
    Rick
    Re: 1960 Courtesy Light Switches - one or two?
    Rick -
    As far as I know, all C1's with courtesy lights had two switches - one on each pillar.
    • Ed Jennings
      Like John, never seen one with just one. With the kick panel loose, you may be able to see the rear of the pillar with a good flashlight and be able to tell where the hole was filled. Another possiblilty is that the one on the left has been added. Courtsey lights weren't standard until 61.
      • Rick Coleman
        Thanks. I'll check it out. *NM*
