64 Fuse - NCRS Discussion Boards
64 Fuse
  • George D. #31849
    64 Fuse
    Can anyone tell me all the components that the very bottom fuse is responsible for on a 64 PG AC Roadster? I have a battery draw and have narrowed it down to that particular fuse.
  • Kenneth S.
    • July 31, 1981
    • 302
    Re: 64 Fuse
    Stop, License & Courtesy Lamps
    • Donald O.
      • May 31, 1990
      • 1588
      Re: 64 Fuse
      George,
      Tonight, in your garage with the lights out, look all around the car, in and out for a courtesy bulb that is still on with the doors closed. It could even be the glove box lamp.
      If not, then you have to begin tracing each wire for a short, not a fun way to spend up to several hours or days, but you will learn an awful lot about your 64 in the process. Good luck.
      Don
      • Bill Clupper
        Re: 64 Fuse
        Keep in mind that if you have to look for a short, per your description of the proble, it would have to be in a power feed to the switch, between the fuse and the switch.
        • Bill Clupper
          Re: 64 Fuse
          Forgot to mention, or in the switch itself.
