Firewall Insulation 65 - NCRS Discussion Boards
  • Mike M.
    • September 30, 1999
    • 710
    Does anyone know of a vendor with the correct type insulation in stock. I have not had any luck finding any. There saying up to 6 weeks. Thanks Mike
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Firewall Insulation 65
    Mike:
    Try Dr. Rebuild at www.drrebuild.com. I bought mine there last year. I remember seeing a post here that stated all the parts houses get the insulation from the same vendor. In my case, my 1965 insulation had to be trimmed in the vicinity of the emergency brake, otherwise it was fine. The upper insulation is made of grey material. The lower insulation is made of green material behind the black tarpaper, but I believe the TIM&JG states that it should be brown, not green. I am not sure which is correct, but the "book" has been known to be wrong many times before.
    Joe
    • Mike M.
      • 710
      I've tried the Dr., Paragon and Corvette Central. I've also emailed a few others with no luck. Thanks Mike
      • John F.
        • July 31, 1999
        • 105
        You might try Long Island Corvette. I purchased my 66 insulation there. It also needed some t*******, but otherwise was OK. I've gone through the same thing purchasing ingition shielding. I had to wait 3-4 months and once one vendor had it, they all had it. Good Luck.
        • Grant M.
          • August 31, 1995
          • 448
          Mike,
          try 'Country Corvette' in Kansas (somewhere just west of Kansas City). I believe that they produce the insulation and therefore may have it in stock.
          good luck!
          grant
          • Mike M.
            • 710
            Thanks Guys LIC Had IT *NM*
