62 overflow - NCRS Discussion Boards
62 overflow
  • Charn Rai
    62 overflow
    Was having a overheating problem, solved by changing fan clutch, drove the car let it idle higher rpms max temp was around 180, using 160* thermostat, when i parked the car noticed coolant overflow, never happened before, any comments would help, thank in advance and have a grand day.
    Re: 62 overflow
    Charn -
    Don't top it off to the "cold fill" line next time after it "pukes", and it probably won't "puke" again. It hot-soaks after you shut it off, increasing coolant temperature and pressure in localized areas until it cools down; if there's enough empty volume in the system to accommodate the expansion, it'll stay dry. Make sure your cap is sealing properly.
    • Charn Rai
      Re: 62 overflow * thanks again John* *NM*
