Wiper transmission C1 - NCRS Discussion Boards
  • Ron B.
    • 58
    Can anyone give me suggestions on how to free up a wiper transmission? It turns alright, but there is no vertical movement to use for the tension adjustment when I try to press it down. Thanks for any help.
  • Ed Jennings
    Re: Wiper transmission C1
    I have repaired several of these by soaking the transmission in penetrating oil for a few days and in some cases lightly tapping the shaft back and forth with a plastic hammer. On one or two I had to finally separate the two pulleys with a chisel, working lightly and VERY CAREFULLY around the perimeter. That was sort of a last resort and I don't recommend it unless you have a transmission that pretty much scrap unless you get it apart.
