Yet Another Judging Question... - NCRS Discussion Boards
  • Rich Beauchamp
    Well, I guess I'm a real novice! Reading the Judging Ref. Manual, it refers to an "Engine ID Stamp Pad" Can anyone tell me where it is on an 82??? Sounds like it should be well cleaned prior to judging.
    Any help will be most appreciated!!!!!!
  • Bill Clupper
    Re: Yet Another Judging Question...
    On the block deck surface foreword of the cylinder head on the passenger's side
      The 'stamp pad' is machined or 'broached' horizontal surface on the block that protrudes forward, just below the passenger (RH) side valve cover.
      • Rich Beauchamp
        Bill, Jack: Many Thanks! I'll be looking after work tonight, should be able to find it with no trouble. Then back to the Q-Tips!
        • Robert C.
          • December 1, 1993
          • 1153
          Rich, The pad on 81-82s are real hard to see down below the AIR pump. There is one little hole,or shaft, to look down to see it.You need a good flashlight.
          • Rich Beauchamp
            Thought I might need a flashlight. Thanks for the warning! That 54 Ford I had in high school was sure a lot simpler to fool with! But in '65, we couldn't even think about looking at a Corvette!
