67 Seats - NCRS Discussion Boards
67 Seats
  • Donald O.
    • May 31, 1990
    • 1588
    67 Seats
    Hello all,
    What color are the seat attaching rails? These are the rails that hold the seat to the floor. The carpets are black and the seats are white. If they are to be black, would they be gloss, semi-gloss, semi-flat, or flat?
    Are the carpets cut/slit to hide the front seat mounting bolts? Thanks in advance.
    Don
  • Donald O.
    • May 31, 1990
    • 1588
    Re: 67 Seats
    With no responses, I'll just paint them black
    Don
    • Donald O.
      • May 31, 1990
      • 1588
      Re: 67 Seats
      Don
      • John M.
        • February 1, 1997
        • 52
        Re: 67 Seats
        Donald.....The tracks which bolt to the floor are plated not painted. The 1967 tech manual describes it as dark grey oxide. The seat bottom frame is painted and should be gloss black.
        If you decide to paint the tracks I would suggest something like Eastwood's cast iron grey. Good luck
        • John M.
          • February 1, 1997
          • 52
          Re: 67 Seats
          • Donald O.
            • May 31, 1990
            • 1588
            Thanks John *NM*
            • Donald O.
              • May 31, 1990
              • 1588
              Thanks John *NM*
              • Myles Kukurudz
                Re: 67 Seats
                Hi Don,
                I believe in the judging manual it describes the rails as being Black oxide finish and yes you need to leave the carpet flaps over the mounting screws
                • Myles Kukurudz
                  Re: 67 Seats
                  Hi Don,
