Posi. rear end fluid - NCRS Discussion Boards
  • Ryan Clark
    What is best for replacing fluid in Posi rear end? 80w90?
    Is there any brand preference of what is available at local parts stores? I have the GM posi additive.
    Ryan
    • 43221
    Re: Posi. rear end fluid
    Ryan------
    GM #1052271
      • 43221
      Ryan------
      GM #1052271
      • Gary S.
        • July 31, 1992
        • 1632
        Joe's advice is always good and I would never go against it since you can usually count on the products of Mr. Goodwrench. However, I use Mobil 1 synthetic differential oil with the GM brand of positraction additive. It has worked well for me for the last 9 years.
        Gary
        • Gary S.
          • July 31, 1992
          • 1632
          Gary
          • Jerry G.
            • April 1, 1985
            • 1022
            Re: Trans lubricant (same)?
            Do you use the same lubricant, 80W90, for the 4sp trans?
            • Jerry G.
              • April 1, 1985
              • 1022
                • 15674
                The proper oil for the old four-speeds is a GL-5 SAE 80W-90 or 75W-90, either mineral oil based or synthetic. This is the same spec as for the diff, less the positraction additive.
                  • 15674
                  • Jerry G.
                    • April 1, 1985
                    • 1022
                    Re: Thanks Duke *NM*
                    • Jerry G.
                      • April 1, 1985
                      • 1022
