65 corvette restoration - NCRS Discussion Boards
  • RICK GUNN
    ON THE UNDERSIDE OF MY VERY ORIGINAL 65 COUPE I HAVE NOTICED A GREEN COLOR ON THE FLOOR BRACKETS RIVETED TO THE BOTTOM OF THE FIBERGLASS..ALSO THIS SAME COLOR IS PAINTED ON THE SIDES OF THE CAR In BACK OF THE ROCKERS..IS THIS A RUST PREVENTATIVE PRIMER..?? WHERE CAN I GET THIS PAINT FOR MY RESTO..?? THANKS..RICK
  • Robert B.
    • March 1, 1992
    • 265
    Re: 65 corvette restoration
    Yes, this is a Green zinc phosphate primer used on brake line clips areas under the dash and the brackets that hold the rockers awa other area I'm sure. L.I. Corvette sells this 1-800 466-6367. Good Luck
    • Robert B.
      • March 1, 1992
      • 265
      • Grant M.
        • August 31, 1995
        • 448
        Robert,
        I thinks it's zinc chromate primer. Also used I believe, on the windshield frame and the dash cross-member. Common in the aviation industry to prime parts.
        grant
        • Grant M.
          • August 31, 1995
          • 448
          Robert,
          grant
          • Jerry G.
            • April 1, 1985
            • 1022
            Are you talking about the emergency brake brackets?
            • Jerry G.
              • April 1, 1985
              • 1022
              • Joe C.
                • August 31, 1999
                • 4598
                Rick:
                The entire steel "birdcage" of the body, and other brackets, etc. (more or less depending on if your car body is Smith, or St.Louis)were primed with zinc chromate. Be forewarned, that the zinc chromates available today, as well as the zinc phosphate substitutes, are formulated with a much more "olive green" color.
                I tried, but failed to find a z-c or z-p of the original color.
                Joe
                • Joe C.
                  • August 31, 1999
                  • 4598
                  Rick:
                  Joe
                    Quanta ( www.quantaproducts.com ) has the zinc chromate primer in both the "light" green and "medium" green shades in quarts for $24.95.
                      • Joe C.
                        • August 31, 1999
                        • 4598
                        Do They Carry It Again?
                        John:
                        Tried Quanta repeatedly for the light green, but all they had was the medium(olive) green. I have not tried them lately, have you?
                        Joe
                        • Joe C.
                          • August 31, 1999
                          • 4598
                          John:
                          Joe
                            Re: Do They Carry It Again?
                            No, haven't tried to order any recently, but they show it on their website.
