c2 pulleys - NCRS Discussion Boards
c2 pulleys
  • William Wilke
    c2 pulleys
    can anyone tell me the correct finish that belongs on the pulleys of a 67 big block, also if anyone has info on the finish on the radiator support it would be appreciated.
    • 43221
    Re: c2 pulleys
    William------
    The water pump pullies were fabricated steel pullies painted semi-gloss black. The crankshaft pullies were either cast iron (most common) or fabricated steel (some AC applications, as I recall). The cast iron pullies were painted semi-flat black and the fabricated steel variety were painted semi-gloss black. The alternator pulley was machined steel zinc plated. Power steering pulley was cast iron painted semi-flat black. AIR pump pulley, if used, was a fabricated steel pulley which was painted semi-gloss black or was phosphate-finished.
    The radiator support was painted semi-gloss black for all 1967 applications.
      • 43221
      Re: c2 pulleys
      William------
      • William Wilke
        Re: c2 pulleys
        thanks for the reply, sorry I did not indicate the pulleys (crank and water) that I was talking about
        thanks again
        • William Wilke
          Re: c2 pulleys
          thanks again
          • William Wilke
            Re: c2 pulleys
            I have another question you may be able to help me with. My 67 has black hood hardware(support, latches). I am under the impression that these are supposed to be shiny metal. Is there any chance that these are supposed to be black?
            • William Wilke
              Re: c2 pulleys
                • 43221
                Re: c2 pulleys
                William-----
                Most of the componets of the hood latches were zinc plated. The return springs were an exception and were, if I recall correctly, black.
                The hood support was zinc plated. The hood hinges were also zinc plated, but they may have received nearly full coverage in a chassis blackout operation
                  • 43221
                  Re: c2 pulleys
                  William-----
                  • William Wilke
                    Re: c2 pulleys
                    I've heard of the chasis blackout, what parts did this cover, and was it factory original or a process done at a later date. Basically, how can I tell if the brackets were supposed to be black or zinc plated.
                    • William Wilke
                      Re: c2 pulleys
                        Re: c2 pulleys
                        C2 chassis blackout was only the mufflers.
                          Re: c2 pulleys
