gas smell - NCRS Discussion Boards
gas smell
  • paul harrington
    gas smell
    My 65 roadster L-79 and my friend's 67 L-79 have the same problem: After shutting the car off in the garage there is a strong gas smell for the first half hour or so that then dissipates in time. Neither car has a detectable leak. In fact my entire fuel system from gas tank to carbeurator is new. My wife can always tell when I've been out for a ride because I smell like fuel!! Both cars run fine. Any ideas, or is this just indigenous to the breed?
    • 43234
    Re: gas smell
    Paul---
    That's how things were in the 60s and previously. Folks today are not used to it since most cars since the early 70s have had evaporative emissions control. 60s and earlier cars still act like 60s and earlier cars, though.
      • 43234
      Re: gas smell
      Paul---
      • Mark F.
        • March 1, 2002
        • 174
        Re: gas smell
        Paul, I had the same experience with my '66 L-79, especially when I drove into the garage and closed the door behind me. Attribute it to Holley carbs and open element air cleaners. This was the time before the EPA got involved in automobile emissions, even in your own garage! Mark
        • Mark F.
          • March 1, 2002
          • 174
          Re: gas smell
          • Dwayne Lord
            Re: gas smell
            I once read to check the powervalve if you have a Holley and you smell gas after driving it...
            I think I read that if they backfire, they can destroy the powervalve and you then have "Holley-itus" or something like that. I don't know if that's very good advice, and I have no idea how to "check" a power valve. Maybe someone else has heard that "folklore" before?
            • Dwayne Lord
              Re: gas smell
                Re: gas smell
                Can be true of early Shark cars with sealed tanks and evaporative recovery system (charcoal cannister). If you fill tank FULL ('topping off' at the gas station), you tax the liquid fuel separator on the tank as well as the charcoal cannister's ability to hold/contain.
                Things have improved so much with modern automotive technology that we tend to forget how things really were in the 'good ole days' and assess performance using benchmarks that are too harsh. Wives are gifted--they have a wonderful nose for stray fuel vapor and let us know FREQUENTLY there's something awry....
                Add to this modern home construction. When these cars were built, the concept of an attached garage was 'new fangled'.... Typically, the garage was detached (out back) and 'minor' evaporative odors went un-noticed. So, there's a combination of change(s) at work. Welcome to the world of classic car!
                  Re: gas smell
                    • 43234
                    Re: gas smell
                    Dwayne----
                    I don't know if a bad power valve on a Holley carburetor will cause excessive fuel vapors or not. However, assuming that it does, if you have a bad power valve, the vapor issue will be the LEAST of your problems.
                      • 43234
                      Re: gas smell
                      Dwayne----
                      • Dave Henderson
                        Re: gas smell
                        In my attached garage, I decided to pull off my air cleaner and fix a leaky fuel line, I let the car idle in between tweaks to monitor the repair (with the garage door open, of course). PCV was disconnected. 90 minutes passed.
                        As I was wrapping things up, the Fire Truck pulls up to follow up on my neighbor's call about the fire at my house. I assured them there was nothing but fuel burning, they laughed. Eye's watering, I went into the house and noticed the kitchen smelled like the inside of an engine. Opened the windows, the fresh smell returned in about 2 hours. The headache went away with 3 tylenols after about one hour.
                        Welcome to the hobby!
                        • Dave Henderson
                          Re: gas smell
                          • Jim T.
                            • March 1, 1993
                            • 5351
                            Re: gas smell
                            Check your carb after about five minutes after you have parked the car in the garage. Look for obvious extenal leaks and then look into the carb and see if the throttle valves are wet with fuel.
                            I have experienced the smell and lowered my float level in my Holley and stopped it.
                            • Jim T.
                              • March 1, 1993
                              • 5351
                              Re: gas smell
