DOLLY FOR 67 CONV, - NCRS Discussion Boards
DOLLY FOR 67 CONV,
  • CLARK
    DOLLY FOR 67 CONV,
    SOON I WILL BE IN THE POSITION TO TAKE THE BODY FOR STRIPPING & PAINT. IS THERE ANYONE THAT HAS PLANS FOR A DOLLY THAT I CAN HAVE OR PURCHASE? I DO NOT INTEND TO DO THES OFTEN SO I INTEND TO BUILD A TEMPORY DOLLY.
  • jim
    Re: DOLLY FOR 67 CONV,
    I have one you can use!!! What's your location?
    • Tony DiGiorgio
      Clark, If you contact ncrs and get the noland adams tape, there is a workbook that comes with the tape that gives you directions on how to build a body dolly that will fit your car exactly. We just built one for my 67, the insturctions were superb. Would highly recommend it, its worth what little money you will spend for the tape and workbook. Tony
      • Wayne
        Try http://www.wizard.net/crpl/dbase1.htm for a plan for a wooden dolly for a '66 Corvette.... you may have to check frame dimensions in your shop manual to ensure that it'll fit the '67 and modify accordingly.
        • clark
          I'm located in S.W. Michigan. If you are close I would be willing to rent it.
          • Gary F. LeDuc
            Re: 69 Q-jet and return fuel line
            Return line in on Fuel filter; AC GF-432(that is what my SB uses any way).
            • Bill Braun #33186
              FOUND! An honest man! *NM*
