59 Ignition switch spacer. - NCRS Discussion Boards
  • Mark Malone
    Hi Guys,
    I am trying to find out whether there is an additional spacer for the ignition switch.
    I have the switch, the plastic facia (this has the printed switch positions on it) and the screw on bezel.
    It appears that there should be a spacer between the switch and the plastic facia in order to lock both the switch and facia to the dash and stop the switch from turning around.
    I have seen a "ferule" advertised and I ordered one but only received another Bezel.
    Any help will be much appreciated,
    Mark.
  • Joe Maulsby
    Re: 59 Ignition switch spacer.
    Mark, there is a chrome plated spacer between the threaded nut and the plastic backplate. It has a raised "notch" that fits into the cutout notch in the plastic backplate and a similar sized notch in the dash. Once you tighten the threaded nut all of the parts will be secure.
    • Joe Maulsby
      • Mark Malone
        Thanks Jo!
        • Mark Malone
          Thanks Jo!
