1108392 starter? - NCRS Discussion Boards
1108392 starter?
  • Jeff Boerio
    1108392 starter?
    Can someone tell me what the 1108392 starter belongs to? It's dated 9 F 10, but I pulled it off my '67 in favor of the correct one.
    - Jeff
    My '67 427/435 Coupe
    • 43235
    Re: 1108392 starter?
    Jeff-----
    The starter originally resided on a 1969 Buick with 400, 430, or 455 cid engine.
      • 43235
      Jeff-----
      • Jeff Boerio
        Wow. That's a long way from home!! I hope I can send it back to a Buick!
        It didn't do the best job starting my 427/435. Glad to have the "right" starter back in my car!
        Thanks Joe!
        - Jeff
        • Jeff Boerio
          Thanks Joe!
          - Jeff
            • 43235
            Jeff----
            It's only "right" with respect to numbers. Functionally, the 1108392 will work perfectly well. Remember, the "numbers" only identify what the starter FRAME started life as part of. After going through a rebuilder's core-stocks, the "numbers" have virtually no relevence, whatsoever. They are strictly an anachronism. Even if the starter were an 1108392 through-and-through it would still function perfectly in your application. But, from a "numbers" perspective, it wouldn't be "correct".
              • 43235
              Jeff----
              • Jeff Boerio
                Joe,
                I understand what you're getting at. It didn't seem to do such a good job on my 427, though. Since putting on the correct bellhousing, starter, and flywheel, the car starts like a champ now.
                - Jeff
                • Jeff Boerio
                  Joe,
                  - Jeff
