'65 327 distributor disassembly - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    Following the Chassis Service Manual, I began disassembly of my distributor. Everything went as the manual indicated, but I've come to a snag. I can't figure out how to remove the thin metal collar that appears to be holding the point base plate. The CSM just says to remove it. It is thin metal and I don't want to damage it by fiddling with it without the straight scoop. Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: '65 327 distributor disassembly
    there is a very small "snap ring" holding it on. find the open end of it and with a small screwdriver pry the end out of the groove and then unwind the rest of the "snap ring" from the groove.
    • Clem Z.
      • January 1, 2006
      • 9427
      • Mark F.
        • March 1, 2002
        • 174
        Thanks, Clem *NM* *NM*
        • Mark F.
          • March 1, 2002
          • 174
