1966 That pulls to the right when hard braking - NCRS Discussion Boards
  • Matt B.
    • August 31, 2001
    • 228
    I'm looking for suggestions to correct the brakes from pulling to the right under hard braking. Hardly noticable under normal braking. Any ideas will be appreciated.
    Thanks, Matt
    Matt Beltowski
    Florida Chapter
    Michigan Chapter
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1966 That pulls to the right when hard braking
    Several possibilities. Brake fluid on one side of the pads, air in one line, alignment(more caster on the left than right), Suspension components worn, bushings etc. Brake line collapsed one one side. PS valve adjustment. Dont overlook the rears as a possible cause also.
    • Wayne W.
      • April 30, 1982
      • 3605
      • Jack layton #896
        Intenal failure of the rubber brake hose leading to the caliper. Located on opposite side of pull direction. Replace all if they are old.
        • Jack layton #896
