Steel Wheels - NCRS Discussion Boards
Steel Wheels
  • Brian W.
    • September 30, 1990
    • 216
    Steel Wheels
    Can someone help me identify four 15" wheels? Painted silver on the face, black on the back. One example of stamping on the front side is
    #1 - in the centre hub section near the wheel nut mounting holes GM K-1-8-2
    and J-22
    #2 on the outer part near the valve stem opening K183 4 valve hole 4 AZ
    Brian
  • james Kekeisen
    Re: Steel Wheels
    Check out the issue of the Restorer that came out just before the current one. It has everything you could ever want to know about corvette wheels and lots of pictures.
    Jim
    • james Kekeisen
      Re: Steel Wheels
      Jim
        • 43221
        Re: Steel Wheels
        Brian-----
        The most important characters in all of those that you've described is the "AZ". This identifies the wheels as the 15 X 8 rally wheels used for Corvettes from 1969 through 1982. These wheels, originally manufactured by Kelsey-Hayes, are still manufactured by the Hayes Wheel Division of Hayes-Lemerz.
          • 43221
          Re: Steel Wheels
          Brian-----
          • Jim T.
            • March 1, 1993
            • 5351
            Re: Steel Wheels
            Are the AZ type wheels still available from GM?
            • Jim T.
              • March 1, 1993
              • 5351
              Re: Steel Wheels
                • 43221
                Re: Steel Wheels
                Jim----
                Yes, they are. GM #327708. However, they currently list for $168.90/each. You can purchase the same wheel, minus the "GM" stamping, from Hayes wheel dealers for about $75.00/each. Hayes number is 81982.
                  • 43221
                  Re: Steel Wheels
                  Jim----
                  • james Kekeisen
                    Re: Steel Wheels
                    You can now get the illusive 15X7s for 68s from Wheel Vintiques Inc. without markings but correct offset.
                    • james Kekeisen
                      Re: Steel Wheels
