1959 trim plate/assist bar assembly - NCRS Discussion Boards
  • Pat Hanley
    I am trying to install a new "corvette" logo plate into the plate bracket. I need some help with a method to bend the new plate into position so I can install the top & bottom chrome pieces. Any hints/directions would be appreciated.
  • Ed Jennings NCRS #1550
    Re: 1959 trim plate/assist bar assembly
    It can be a bit aggrivating, but if you start at one end and work around it will eventually all fit together. Patience is a virtue with those things.
      • Loren L.
        • April 30, 1976
        • 4104
        Get some strong rubber
        bands and an assistant - fit the three pieces on one end together, band it and move inward, adding more as needed. When you get to the other end and want to make it permanent, J&B Weld sometimes works as well as solder.
        • Loren L.
          • April 30, 1976
          • 4104
