C1 Steering wheel orientation - NCRS Discussion Boards
  • Mike G.
    • April 30, 2001
    • 180
    A few weeks ago, there was some discussion of this, but there were conflicting opinions. First, when the front wheels are straight ahead, do the spokes of the steering wheel form a "Y", or is there one spoke that is staight up, so it looks like the Mercedes-Benz symbol?
    Second, from the driver's seat, are the two pins on the hub that hit the canceling cam to the right or the left? My car's a '58. Thanks, as always!
  • Mark Malone
    Re: C1 Steering wheel orientation
    Mike,
    I would presume that the spokes should be at the "10 to 2" position allowing an unobstructed view of the instruments and I'll check the canceling pins shortly.
    Mark.
    • Mark Malone
      Mike,
      Mark.
      • Mark Malone
        Mike,
        My wheel has a small letter "M" stamped at what I believe to be the top of the wheel. There is also a small line or "I" stamped into the top of the column shaft.
        If this letter "M" is placed at the top position (the line @ top and wheels straight ahead) then the cancelling pins are on the left if viewed from the drivers seat.
        With this combination, the indicator cancels within 1/6th of a turn in either direction.
        Hope this helps,
        Mark.
        • Mark Malone
          Mike,
          Hope this helps,
          Mark.
            With the wheel correctly installed (like a "Y", with the index mark on the steering shaft at 12 o'clock) and the wheels straight ahead, the cancelling pins on the wheel hub should be at 8 and 10 o'clock.
              • Mike G.
                • April 30, 2001
                • 180
                Thanks Mark & John! *NM*
                • Mike G.
                  • April 30, 2001
                  • 180
