C3 1968 dash mounted ignition - NCRS Discussion Boards
  • Jim Kekeisen
    The spring that brings the key back to the run position has gone south ie if I start the car and let go of the key the starter continues to turn. Never having had one apart is it serviceable? I was trying to avoid replacement and having to rekey to match the doors etc.
    Jim
    • 43229
    Re: C3 1968 dash mounted ignition
    Jim-----
    These switches were not designed to be serviced except as a complete assembly. However, I think that they can be repaired if one is careful and innovative. You won't be able to purchase any internal parts to repair them, but you can cannabilize parts from another "sacrificial" switch or use fabricated/standard parts from a hardware store.
    If your attempts to repair the switch fail or fail to produce a satisfactory repair, then you've lost very little. In that case, you resort to "Plan B" and use a new switch. A locksmith can code the cylinder to match the other locks without too much trouble or expense.
      • 43229
      Jim-----
      • Bill Clupper
        Jim, the same process Described in my Restorer article regarding C-1 switch repair can be used on your '68, just a matter of obtaining a donor NOS part with the same electrical pinout configuration.
        • Bill Clupper
          • james Kekeisen
            Are "donor NOS parts" a corvette only part?
            • james Kekeisen
              • Jim T.
                • March 1, 1993
                • 5351
                James I have seen NOS 6 ignition switches in the NCRS Driveline in the past 6 months that are reasonably priced.
                • Jim T.
                  • March 1, 1993
                  • 5351
                  • Roberto L.
                    • January 1, 1998
                    • 523
                    A very few days ago there was one offered in e-bay, photo included. perhaps it is still offered!!
                    Roberto, NCRS #30019, RMC
                    • Roberto L.
                      • January 1, 1998
                      • 523
                      • Roberto L.
                        • January 1, 1998
                        • 523
                        check e bay item #1825555847, could be what you are looking for. I have no interest in the transaction.
                        • Roberto L.
                          • January 1, 1998
                          • 523
                          • Larry Sherman
                            My recollection of changing out the igniton switch in my 68 is that I changed the switch and retained the lock cylinder portion, which was a separate part. I bought the new switch at an auto parts store. Larry
                            • Larry Sherman
