72 rear wheels conforming to the road? - NCRS Discussion Boards
  • Eric Fairclo
    I have noticed the rear wheel on my 72 seem like they are conforming to the road such as when i have it parked in the garage it looks like the top of the rear wheels are in a slight bit and the bottom are out just like the garage floor because of the drain in the center of th floor. When i park it on a flat area they are straight. I think this is because it has the half shaft configuration. I have only had solid axle cars before now. Is this supposed to be like this?
    • 15684
    Re: 72 rear wheels conforming to the road?
    The rear should have a bit of negative camber at normal ride height and thee is considerable camber change with jounce and rebound. The camber spec for your year is in the Chassis Service Manual and you can measure it using a hardware store inclinometer with the car on a level surface.
      • 15684
