grey / black fiberglass (67 sb fan shroud) - NCRS Discussion Boards
  • Zachary K.
    • March 1, 1986
    • 162
    I need some help as to how to make a repair to a 67 small block rad fan shroud, which for judging purposes needs to be natural as opposed to the big block fan shrouds that were painted. What can I add to the fiberglass resin to give it this grey / black appearance. Like possibly adding graphite powder. The repair is a small one but is on the top side and in a noticable area. Any suggestions as how to help mask this repair and make the appearance look 100% natural will be greatly appreciated. Thanks
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
  • Brandon K.
    • April 1, 1997
    • 474
    Re: grey / black fiberglass (67 sb fan shroud)
    I bought some color additive (black) from a marine supply store. You need to add a bunch of it AFTER you catalyze the resin. It is a lot better than the yellow/ green color of most resins, but still not quite a perfect match. You can use this stuff and then dust some paint on after you repair and sand down.
    • Brandon K.
      • April 1, 1997
      • 474
