67 427/435 backfire. - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    What would be the most likely cause of a backfire through the drivers side exhaust when the engine is reved in neutral? Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 427/435 backfire.
    air leak in the exhaust system
    • Clem Z.
      • January 1, 2006
      • 9427
        • 15676
        Afterfire, not backfire
        It's call "afterfire" when you hear the pop in the exhaust. Backfire is when it hiccups back through the carburetor. Afterfire could be caused by a lean mixture or a leaky exhaust valve. Try richening the idle mixture a bit, and a leakdown or compression check should reveal if you have a leaking valve.
          • 15676
