Of the six upper bolts across the top (two left, two center, two right) on the 66-67 Big Block Radiator support - I understand each requires a sleeve which prevents the radiator support from crushing when the bolts are tightened. The sleeve is a round tube approximately 3/4" in length and 1" in diameter. One end is cut evenly while the other end has a small 1/4" section cut from it.
Can anyone explain how the cut end is placed when installing? Iv'e checked the AIM and did not find detail on this.
