67 Engine # question - NCRS Discussion Boards
  • David Pickering
    I am looking at purchasing a 67 convertible 327/350 with factory air conditioning and power steering. The engine code is HT which according to my research is a 327/350 base car. The 327/350 with factory air conditioning and power steering should be HP - am I correct in this assumption?
    All the other numbers check out and it the Engine ID and VIN no check out OK. This will be my first Corvette after years dreaming about it and I intend to show the car so I don't want to make a mistake.
    Any help or advice would be very gratefully received.
    • 43229
    Re: 67 Engine # question
    David----
    Your research is correct. However, it's not out of the realm of possibility that an "HT" coded engine could have been used for the A/C with P/S application. Or, it's, of course, also possible that A/C and P/S was added to the car somewhere along the line.
      • 43229
      David----
