1967 Dash bulb specs - NCRS Discussion Boards
  • Brian M.
    • February 1, 1997
    • 1839
    What is the difference between an 1816 bulb and an 1893 bulb? The 1816 is used for inst. panel, clock, radio, brake warning. The 1893 is used for glove box, heater control panel, A/C panel. They are both 3 watt bulbs and appear idenical. So what is the difference? FYI 1967 coupe. Thanks Brian
  • Geoff C.
    • May 31, 1979
    • 1613
    candlepower: 1893=2; 1816=3 *NM*
    • Geoff C.
      • May 31, 1979
      • 1613
      • John Amgwert
        Re: Dash bulb specs
        My specs indicate both 1816 and 1893 bulbs were rated at 3 candlepower.
        • John Amgwert
          Re: Dash bulb specs
            Re: 1967 Dash bulb specs
            Although bulbs can have similar power consumption (watts) and output (candlepower) specs, they can differ in other ways: (1) bayonet barrel style, (2) globe geometry, (3) filament design & geometry....
              • Brian M.
                • February 1, 1997
                • 1839
                I will do a closer examination this eve. IE: magnifying glass & wife.
                • Brian M.
                  • February 1, 1997
                  • 1839
                  • Roberto L.
                    • January 1, 1998
                    • 523
                    Hello, in the 70 owners and service manuals the 1816 is specified as a 2.5 candel pw and 1893 as 2 cp. That's a difference, supposing the bulbs are the same in those years as the #s are.
                    Roberto, NCRS #30019, RMC
                    • Roberto L.
                      • January 1, 1998
                      • 523
