rare water pump - NCRS Discussion Boards
rare water pump
    • 43222
    Re: rare water pump
    clem-----
    That particular part number I can come up with nothing on whatsoever. I don't think that it was ever used for any Chevrolet application. It may be some other car line.
      • 43222
      Re: rare water pump
      clem-----
      • Sal C.
        • December 1, 1984
        • 430
        #18
        Re: rare water pump
        From what I understand, that type of part numbering sequence does indicate a part as being a "prototype" item from GM.
        • Sal C.
          • December 1, 1984
          • 430
          #19
          Re: rare water pump
          • John Amgwert
            #20
            Re: OH-Dash Numbers
            As I recall, when Chev. Engineering did special (internal) projects, be they prototype, experimental, etc., etc., they were assigned special numbers that began "0-xxx.." and they were often called "OH-DASH" numbers. These numbers got stamped into many parts to identify the specific project. You'll see many of these OH-DASH numbers stamped into the special Chev. engines on display at the Corvette Museum.
            • John Amgwert
              #21
              Re: OH-Dash Numbers
                Re: OH-Dash Numbers
                Could well be an "escaped" prototype piece with the "0-" part number; we made a LOT of "0-" BB parts in mid-to-late '68 in development for the coming run of aluminum blocks for the Camaro ZL-1 program the following February and for the Reynolds blocks for the upcoming Can-Am season for Bruce and Denny. Sounds interesting
                  Re: OH-Dash Numbers
                  • John W.
                    Administrator
                    • November 1, 1974
                    • 5087
                    #24
                    Re: Would it fit this car?
                    Ronnie,
                    Would this water pump fit a car like this?
                    John,
                    Administrator
                    www.ncrs.org
                    • John W.
                      Administrator
                      • November 1, 1974
                      • 5087
                      #25
                      Ronnie,
                      John,
                      Administrator
                      www.ncrs.org
                      • Bill Braun #33186
                        #26
                        Ohhhh, Momma...
                        buy me THAT!
                        ":D">
                        • Bill Braun #33186
                          #27
                          Ohhhh, Momma...
                          buy me THAT!
                          ":D">
                          • Art A.
                            • June 30, 1984
                            • 834
                            #28
                            Re: rare water pump
                            Ron, To help clarify this part and part number issue I would like to add the following:
                            Apparently the 0 dash part numbered part you have is/was a GM experimental part, if in fact the number characters are all the SAME size and of uniform typeface. As John Hinckley has stated " Could well be an--- "escaped" prototype piece with the "0-" part number"----- as there were many "avenues" where 0 dash parts got out of GM's hands. What part of the country is your vehicle originally from?
                            The rest of the both the numbers you mention, (294 581 AL--I don't know what the AL is, it is not consistence with the GM part number system and 309 383), belonged to a BLOCK of part numbers that were issued to the TRUCK AND BUS GROUP----------------Note: This does NOT necessarily mean that it is a T & B prototype part. Chevrolet Engineering could/did "borrow" part numbers from other divisions for "prototype piece's " in order to keep certain projects under raps---if you know what I mean! OR it simply could have been a prototype part for T & B engine.
                            Art
                            • Art A.
                              • June 30, 1984
                              • 834
                              #29
                              Re: rare water pump
                              Art
                              • Ronald D, Rains
                                #30
                                Re: rare water pump
                                This pump was used on one of the early Chap. cars in nearby Midland texas. I think i have rounded up enough par5ts to repair the pump. Thanks to all for the help.
                                Ronnie
