1961 Expansion Tank Strap Bolt - NCRS Discussion Boards
  • Greg Stoico
    This is not a technical question as much as it is a "where can I find?" question.
    I'm looking for an expansion tank strap bolt with an "E" on the head for a 61'. The bolt I have on it now has a circular pattern. There is an incomplete outer circle connected to an incomplete inner circle. Could this be correct as well? This nut and bolt detail can where one thin!!
  • Mike Przano
    Re: 1961 Expansion Tank Strap Bolt
    Greg,
    Check with Paragon, they probably have it.
    Mike
    • Mike Przano
      Greg,
      Mike
      • Greg Stoico
        Thanks Mike, but I have tried just about parts company out there (I buy so much from Paragon, I get the discount). I'm told that no one can reproduce the bolt due to copy right infringment. Not sure how true it is. I guess I need to find an original. Thanks Greg
        • Greg Stoico
          • Greg Stoico
            Re: Many Thanks Gary
            Gary, thanks again. I owe you one!!! Or two........
            • Greg Stoico
