58 spark plugs - NCRS Discussion Boards
58 spark plugs
  • Kris Schmalenberg
    58 spark plugs
    Pulled the plugs today and found a few to be quite fouled. I have a 245 Hp dual quad setup but I am running the duntov cam. I was wondering what others who drive their cars often are running for spark plugs. Im running 45 but could I go as hot as a 46? Does anyone run a hotter plug in just those cylinders that tend to get fouled?
    Re: 58 spark plugs
    Kris -
    I run 45 or 46 equivalent plugs in my '57 270 (and in my factory way-over-carbureted '69 Z/28) with few problems; AC doesn't make the 46 any more, but the 45S or Champion J14YC work OK for me. Other equivalents include Autolite 76 (non-resistor) or 86 (resistor) and Denso W14P-U (45 equivalent) or W9P-U (46 equivalent). 46's were used in later 2x4 production, and there were several Service Bulletins notifying dealers to replace 43's and 44's with 46's on customer-complaint 2x4's with fouling problems.
      Re: 58 spark plugs
      Kris -
      • Dave S.
        • August 31, 1992
        • 2926
        Re: 58 spark plugs
        Kris,
        Some on this board are not in aggreement with me on this, but I believe the older(pre 1975) AC delco spark plugs are of extremely high quality and are an excellent option for older Corvettes. They are available in a variety of heat ranges and configurarions i.e. extended tip, resistor etc. I use 45's in my 59 245 HP car and have had excellent results. The 46 heat range is popular with the fuel injected cars. Some like the S(extended tip) plugs as they feel the spark is closer to the piston. These plugs can be cleaned with an abrasive plug cleaner and remain useable.
        • Dave S.
          • August 31, 1992
          • 2926
          Re: 58 spark plugs
          Kris,
          • Ed Jennings
            Re: 58 spark plugs
            Use the extended tip plugs with caution on an engine with domed pistons. On my 62 FI, they will contact the pistons if turned just right. May be ok in another engine depending on size and configuration of dome.
            • Ed Jennings
              Re: 58 spark plugs
              • Dave S.
                • August 31, 1992
                • 2926
                Re: 58 spark plugs
                To take your comment one step further,it would be appropriate to "index" the S (extended tip) plugs to avoid any piston contact. It takes a few extra minutes but will give you peace of mind.
                • Dave S.
                  • August 31, 1992
                  • 2926
                  Re: 58 spark plugs
