65 Door Panel Removal - NCRS Discussion Boards
  • Barry M.
    • September 30, 1975
    • 1
    How do you remove the chrome lock piece on the inside rear of the door panel??
  • Ryan Clark
    Re: 65 Door Panel Removal
    It has a "C" clip similar to the vent window handle.
    If it is anything like mine, it is a pain to get out.
    There is a "C" clip removal tool.
    Ryan
    • Ryan Clark
      Ryan
      • Bill Stephenson
        Carl,
        ------Very hard to use most c-clip removal tools on the door locks.Years ago I took a 90 degree pick that had the tip broken and shortened it up.With just barely a turn on the end of the pick,you can go in and grab the c-clip and pull it out.You will have to push the doorpanel back just far enough to get a glimpse of the clip so you can see where to pull from.Just be careful and you will get it and never damage the door panel.......Bill S
        • Bill Stephenson
          Carl,
          • Wayne K.
            • December 1, 1999
            • 1030
            An angled pick works or you can make one from a heavy paper clip. Hook the loop of the clip and pull it out.
            • Wayne K.
              • December 1, 1999
              • 1030
