Need Help Identifying 3 speed case - NCRS Discussion Boards
  • Rod Wagner
    The main case for my '60 3 speed has the following casting numbers
    GM
    28
    3743368 E-9-0.
    I am guessing the E-9-0 would stand for May 9, 1960, which would match the rest of the car, but do the rest of the numbers make sense?
    Rod
    • 43241
    Re: Need Help Identifying 3 speed case
    Rod-----
    The rest of the numbers make complete sense. The "GM" obviously refers to General Motors. The "28" is the mold number. The "3743368" is the casting number for the case which, as I vaguely recall, is correct for 1960.'ll need to confirm that, though.
      • 43241
      Rod-----
      • Rod Wagner
        Joe,
        Thanks for your help.
        The car appears to be fairly original, but I had a problem with a Syncro for it and needed to be sure someone haden't changed the main case.
        Thanks again
        Rod
        • Rod Wagner
          Joe,
          Thanks again
          Rod
