62 Bolt Head Markings - NCRS Discussion Boards
  • Terry Van Slooten
    I'm having trouble finding information on the following bolt markings, size, type and finish for the following applications, can anyone help please? Center bolt and washer for harmonic balancer to crank, (3) pully bolts to harmonic balabcer and finally the bolts used to attach splash sheilds to inner fenders and frame. Thanks Terry
  • Wayne C.
    • November 1, 1978
    • 289
    Re: 62 Bolt Head Markings
    Get a catalog from Paragon Reproductions http://www.corvette-paragon.com
    They carry a lot of correct bolts, including the pulley bolts you seek.
    • Wayne C.
      • November 1, 1978
      • 289
      • John M.
        • January 1, 1999
        • 1553
        The spash shield bolts should be TR head mark cap screws with flat washers on both sides and lock washers on the engine side under the nuts. All hardware should be cad or zinc plated. The fasteners that attach the splash shields to the frame should be hex head self-tapping indented head screws in black finish, and no washers should be used under the heads of the screws. This is what was on my 60 and since the 62 uses the same splash shields, I would presume them to be the same. John
        • John M.
          • January 1, 1999
          • 1553
