Wiper Override Switch Assy finishes - NCRS Discussion Boards
  • Juliet P.
    • June 30, 1999
    • 349
    While it's out of the car I figured I'd repaint the bracket and clean up the override assy from under the steering column. I saw no description of the finishes in the TIM&JG. It would appear that the metal bracket is gloss black (from what's left of the paint on mine). Is this correct? Also, I have 2 different washers on the pull knobs for the wiper door / headlight door overrides. What is the original factory finish supposed to be? One of mine is rusted (shiney where it was covered up). The other one with a larger center hole is shiney unfinished silver metal. I think that's probably a replacment one but I don't know for sure. Also, are the 2 screws black oxide? Again, mine are quite rusty. Do the 2 vacuum switchs and the center knob assy look original? Obviously someone was in here before for some reason since that washer is a replacement one - I'm curious if something failed and one of these parts are replacements or if the washer was just lost when the steering column was out for rebuilding (I didn't do that work myself). But from those colored daubs on the vac lines I figure those are originals since those marks appear on a lot of original vac parts, but I really don't know for sure. To those of you with originals or who know what is / isn't original, what do you have? Thanks, ~Juliet
    Here are some pictures - You might need to copy & paste the URL for it to come up properly as CF has disabled outside pic linking from outside their site.
    2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
    1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
    1965 Coupe (Greg's project No Flight)
    Gone but not forgotten:
    1987 Yellow Convertible 199k mi.
    2002 Yellow Convertible 100k mi.
    2007 Atomic Orange Coupe 140k mi. RIP flood 2015
    2007 Lemans Blue 6-Spd Coupe 34k mi.
  • Juliet P.
    • June 30, 1999
    • 349
    Forgot to say, 1970 Convertible *NM*
    • Juliet P.
      • June 30, 1999
      • 349
      • Roberto L.
        • January 1, 1998
        • 523
        Re: Wiper Override Switch Assy finishes
        Hello Juliet, in my 70 the bracket is semigloss black as other hard parts in the interior (black interior). Good that you have the big knob.
        Roberto, NCRS #30019, RMC
        • Roberto L.
          • January 1, 1998
          • 523
          • Juliet P.
            • June 30, 1999
            • 349
            Thanks! Washer Finish?
            Thanks Roberto. That's good to hear. What color are the washers under the cross recess screws on your '70? Should mine be natural metal or black or something else? ~Juliet
            • Juliet P.
              • June 30, 1999
              • 349
              • Roberto L.
                • January 1, 1998
                • 523
                Re: Thanks! Washer Finish?
                One of the washers I found was natural, I beleive it is the original, Juliet. It looks like the one in your photo. The other was different and clearly a replacement, apparently a previous owner in your country made a quick fix using any washer.
                • Roberto L.
                  • January 1, 1998
                  • 523
