1957 F.I. Thermostat Housing Correct Number - NCRS Discussion Boards
  • Stubby 57
    Can anyone tell me if #3837223 is a good Thermostat Housing number for a 1957 Fuel injected early car? If not, what is the correct number and what would this number mentioned above be for?
    Thanks for your help
  • James F.
    • December 1, 1985
    • 596
    Re: 1957 F.I. Thermostat Housing Correct Number
    Stubby, 3837223 is a good number for the housing. SACE believes there were four versons of the aluminum 3837223 housing, all very similar but with slight differences. The 1st verson which would correspond with your early '57 F.I., had the part # located on the left side of the housing, the neck was thin and the base was solid.
    • Stubby 57
      Jim, Thanks for the response, it really helped
      Stubby 57
