68 Steering Column - NCRS Discussion Boards
68 Steering Column
  • Dave Kearney
    68 Steering Column
    Hello All--
    Looking at the steering column on my '68 it appears to not be a telescoping version. However, when I look through the AIM, there are several pictures depicting telescoping steerign columns. Was this a stock item or was it available as an option in 1968? If so, where could I obtain the necessary parts to convert mine to a telescoping column? Thanks!
    Dave
  • John D.
    • August 31, 2001
    • 280
    Re: 68 Steering Column
    Dave:
    UPC 9, Pages A4 thru A6 may help you.
    Tom Reina CV Steering 864-287-9990, http://corvettesteering.com
    He did an excellent job on my steering gear box and should have everything you need.
    I have a question for you, could you send me an e-mail with your 68 build date. If it is close to mine October 1967, I would like to ask you some questions about your door panels.
    Thanks, John
    • John D.
      • August 31, 2001
      • 280
      Dave:
      Thanks, John
      • Geoff C.
        • May 31, 1979
        • 1613
        Converting Std 68 to Tele
        It is easy, just plan on replacing almost everything between the horn button and the steering box.
        • Geoff C.
          • May 31, 1979
          • 1613
            • 43221
            Re: Converting Std 68 to Tele
            Geoffrey and Dave------
            That's EXACTLY how it is. The only way to "convert" a 68 (or any other Corvette, for that matter) from a standard steering column to a telescopic (65-68) or tilt-telescopic (69-79) is to replace the entire steeing column.
            Making matters worse, the 68 Corvette telescopic steering column is unique to 68 Corvettes. So, you have to obtain a used column out of a 68 to perform the conversion on your car.
              • 43221
