Lifting Motor - NCRS Discussion Boards
Lifting Motor
  • Larry Gawron
    Lifting Motor
    I need to change the motor mounts on my '76. The engine is in the car but all accessories (carb, water pump, A/C, PS, etc) are removed. What is the best way to lift the engine? Can I place a floor jack with a wood block under the oil pan? Can I lift it by the harmonic balancer?? Please help!
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Lifting Motor
    Strap a chain using 3/8 bolts into the water pump mounting holes and lift via the chain with a cherry picker. Easy, quick and simple. Be carefull if you jack against the oil pan, it's only sheet metal and will dent.
    • Gene M.
      • April 1, 1985
      • 4232
      Re: Lifting Motor
      • Gary S.
        • July 31, 1992
        • 1632
        Re: Lifting Motor
        If all you are doing is changing out the engine mounts, I would try a floor jack, with an appropriate sized piece of plywood between the floor jack and oil pan, and lift the engine the couple of inches necessary to get the engine mounts off.
        Gary
        • Gary S.
          • July 31, 1992
          • 1632
          Re: Lifting Motor
          Gary
            Re: Lifting Motor
            Rather than taking a chance on damaging the now-discontinued original oil pans, I made a simple "U"-shaped saddle years ago with a 2"x 6" for the base and 1"x 6" for the sides, slightly taller than the depth of the pan, with the inside width about 1/4" wider than the pan. The top edge of the side pieces pick up on the pan bolts, and I jack under the 2"x 6" base piece to raise the engine. C1 water pump changes make it necessary to hold up the engine, and this simple saddle makes it quick and easy with no damage to the pan. Link below shows this incredibly complex device
            Engine Lifting Saddle
              Re: Lifting Motor
              • Larry Gawron
                Re: Lifting Motor
                Thanks for the help. I am going to try the saddle. It seems like just the tool I need. Thanks again.
                • Larry Gawron
                  Re: Lifting Motor
