More than one bottle of differential additive? - NCRS Discussion Boards
  • Lonnie Wiggins
    If I stop my '69, and then start up again, or, if I stop and reverse...sometimes I'll get a thunk and shudder from the differential (I presume, as everything else seems tight - checked the differential to frame snubber/bolt assembly).
    I know the differential contains one bottle of additive. Could it need two?
    Has anyone ever seen an situation where more than two were needed?
    • 15601
    Re: More than one bottle of differential additive? *TL*
    The 1969 Corvette FSM, I believe, calls for one bottle, but those of us with late model Caprice/Impala B-bodies routinely use two in spite of the applicable FSM calling for one. The limited slip mechanism is very different in the B-bodies than the Corvette, however. I don't think two bottles will hurt - other than your wallet.
    How long has it been since you changed the differential fluid? After years and years the fluid, and positraction additive, need replacement. You might try that as a first - least costly - option.
      • 15601
        • 15676
        If you don't know the last time the fluid was changed, change it using the GM axle oil and one four ounce bottle of the additive. Also measure the circumference of the tires. If they vary more than about 1/2" that can cause problems with the positraction.
        If the tires are okay and it still makes noise, add a second bottle. If that doesn't cure the problem, then it's probably something else - maybe an internal problem in the axle.
          • 15676
          • Mark Ring
            Yes I did need more than 1 bottle but it was in a Camaro. I had the differential swapped out and the new one would snap on freeway cloverleafs etc. The second bottle did the trick.
            -Mark.
            • Mark Ring
              -Mark.
              • Wayne W.
                • April 30, 1982
                • 3605
                I routienly use two.
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  • Steve D.
                    • February 1, 2002
                    • 990
                    Is differential additive used in all posi-traction differentials, or just later models?
                    • Steve D.
                      • February 1, 2002
                      • 990
                        • 15676
                        All
                        The additive is a "friction modifier" that prevents "slick-slip" friction that causes the chatter we can experience.
                        All Corvette positraction axles require it for smooth chatter free operation, and automatic transmissions fluids have a similar additive to keep their wet clutches operating smoothly.
                        The additive appears to degrade with time, which is why the fluid should be replaced with new fluid and additive every 30K to 60K miles.
                        It's best to use the least amount of additive to eliminate chatter because too much will reduce the effectiveness of the positration unit.
                        There are several types of limited slip differentials. The "clutch" and "cone " type as used by GM require the additive. Purely mechanical types such as "ratchet" (Detroit Locker), the worm gear type (The name escapes me for the moment.) and the "viscous" type do not need the additive.
                        Back in the fifties and sixties the additive was whale oil based and the old Type A Suffix A ATF had a whale oil additive. With the outlaw of whale products in the US in seventies an alternative petroleum derived product was developed.
                          • 15676
                          All
                          • andy#34338
                            Just had to add a second to my new 3.55 in my 60
                            I put a new 3.55 in my 60 an after a couple hundred miles it started making binding noises mostly on turns. Added a second bottle and no more issues.
                            Andy
                            • andy#34338
                              Andy
