Positraction rear end lube - NCRS Discussion Boards
  • Jerry A.
    • May 31, 1997
    • 122
    For a positraction rear end do you recommend using a synthetic or mineral base lube? Why?
    • 15676
    Re: Positraction rear end lube
    I recommend the GM axle oil and additive because they are compatible, and I know they work. I haven't tried any of the modern synthetics, but I've heard that Redline 75W-90 works well as it because it already has the additive added.
    I don't think a synthetic is much of an advantage in a street driven car because the diff isn't going to get the oil hot enough for the sythetic's higher thermal breakdown temperature to do much good, so I just stick with what I know works.
      • 15676
      • Jerry A.
        • May 31, 1997
        • 122
        Thanks Duke
        Jerry
        • Jerry A.
          • May 31, 1997
          • 122
          Thanks Duke
          Jerry
            • 43221
            Jerry and Duke-----
            Although I'm a big fan of synthetics, I also recommend the use of the conventional GM positraction gear lube and additive. These have worked so perfectly for so long that I'm reluctant to use any newer technology for this application.
              • 43221
              Jerry and Duke-----
              • Jerry A.
                • May 31, 1997
                • 122
                Thanks Joe. Appreciate your help!
                Jerry
                • Jerry A.
                  • May 31, 1997
                  • 122
                  Jerry
                  • Don Shirey
                    Midyear Positraction rear end lube capacity?
                    Hi guys,
                    Can anyone tell me the approx. amount of Posi lube and
                    additive for a midyear. Couldn't find spec. in 63-65 manual
                    and supplements.
                    Don #31553
                    • Don Shirey
                      Hi guys,
                      and supplements.
                      Don #31553
                        Re: Midyear Positraction rear end lube capacity?
                        Don -
                        Capacity is about 3-3/4 pints; put a 4-oz. bottle of GM Posi Additive in first, then add the hypoid lube.
                          Don -
                          • Don Shirey
                            Thanks John, see you Sunday! *NM*
                            • Don Shirey
