Ignition switch-'59 - NCRS Discussion Boards
Ignition switch-'59
  • Paul Robinson
    Ignition switch-'59
    I am having trouble with ignition ... no juice whatsoever to the starter. when I hotwire the wires coming out of the ignition switch (new from CC)I get spark, which indicates that the ignition switch is faulty. Can it be repaired or do I need to replace the entire switch?
  • Bill Clupper
    Re: Ignition switch-'59
    It can be repaired, see my article in the "Restorer" from a couple of years ago. The same parts and procedure describer there will work for your switch.
    • Bill Clupper
      • Paul Robinson
        Is your article on the Corvette Restorer CD?
        • Paul Robinson
          • Dave S.
            • August 31, 1992
            • 2925
            Paul, My experience is that reproduction ignition switches are not real good. Even the bezel nuts don't screw on very well. I went through the same thing with the 59 and then decided to find an NOS switch. Good used or NOS switches will work quite well and are fairly easy to find.
            • Dave S.
              • August 31, 1992
              • 2925
              • Mike G.
                • April 30, 2001
                • 180
                Ditto Dave's comment. The first repro ignition switch for my '58 was faulty, but the second (also a repro) was fine. The bad part was the amount of time it took to figure out that my problem was not in my wiring, but in a brand new component.
                • Mike G.
                  • April 30, 2001
                  • 180
