Intake Manifolds - NCRS Discussion Boards
Intake Manifolds
  • John Mathieu
    Intake Manifolds
    Can you still get intake manifolds for the 396/425?
    John
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Intake Manifolds
    if you are not into matching #s,coprrect date thing GM still sells a BB manifold under part# 3933163 that was used on most hi per BB engines from the factory
    • Clem Z.
      • January 1, 2006
      • 9427
        • 43221
        John------
        The original manifold for a 1965 Corvette L-78 was GM casting #3866963 which was GM PART #3876826. This manifold was discontinued in October, 1966. Since it was only used on 1965 Corvettes and passenger cars with L-78 as well as Chevelles with the Z-16 option (very rare), it's a very scarce manifold to find used.
        The GM #3933163 manifold which Clem mentioned is VERY similar to the 3866963. The primary difference is the fact that the 3933163 has provisions for a divorced-style choke used for 1966+ applications; the 3866963 does not have such provisions. In any event, the 3933163 will function perfectly for the 1965 L-78 application and it will appear similar to the original but it won't be "correct".
          • 43221
          John------
          • John Mathieu
            Thank you all! *NM*
            • John Mathieu
              Thank you all! *NM*
              • Jack layton #896
                Go to Goggle. Dial in 3866963. You might find one that easily. They have been offered on e-bay in the past. Try the part number or phrases like "intake corvette" "BBC intake" " 396 intake" "427 intake" you get the idea.
                • Jack layton #896
