61 Steering Column Removal - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Is there a simple way to remove the entire 1961 steering column shaft? I need to repaint the upper portion to match my interior color. Thanks, Craig
  • John M.
    • January 1, 1999
    • 1553
    Re: 61 Steering Column Removal
    Craig, you will need to drop the column inside the car, remove the plate at the firewall, remove the pitman arm, and unbolt the box from the frame. The box will need to be rotated with the sector shaft up and then the entire column and box can be slid out. Obivously, the hood would need to be removed. John
    • John M.
      • January 1, 1999
      • 1553
        Be glad you don't have a '57 - they don't have a removable "saddle" at the instrument panel like '58-up do - makes it even more fun
