Antenna ground plane for 65 - NCRS Discussion Boards
  • Rob M.
    • June 30, 1999
    • 171
    Is there suppose to be any coating on the antenna ground plane? Mine has a brown (or dirty yellow) splotchey coating on both sides. It does not cover 100% of the aluminum - like it was sprayed very lightly from a distance. It does not cover the steel reinforcement plate around the antenna hole. That part is natural (rusty). What is the correct finish / appearance for these parts.
    Rob
    My Project Pictures
    http://temp.corvetteforum.net/classics/l78vetteman/
  • Peter L.
    • May 31, 1983
    • 1930
    Re: Antenna ground plane for 65
    Rob - The finish of the antenna ground planes I have seen from the Corvettes I've worked on have been natural aluminum. The surface is usually oxidized and might have some pitting but no evidence of specifically being painted or coated. Pete
    • Peter L.
      • May 31, 1983
      • 1930
