Glovebox lock - NCRS Discussion Boards
Glovebox lock
  • Grant M.
    • August 31, 1995
    • 448
    Glovebox lock
    Assuming it's in the 'unlocked' position, can the glovebox lock be removed without the key?
    Thanks!
    grant
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Glovebox lock
    You don't say what year car you are asking about?
    • Bob R.
      • June 30, 2002
      • 1595
      Re: Glovebox lock
      • Grant M.
        • August 31, 1995
        • 448
        Re: Glovebox lock
        Sorry, it's a '65.
        • Grant M.
          • August 31, 1995
          • 448
          Re: Glovebox lock
          Sorry, it's a '65.
          • Peter L.
            • May 31, 1983
            • 1930
            Re: Glovebox lock
            Grant - I trust you are referring to removing the lock core from the case. There's a opening or small slot in the front of the case that allows you to release the locking tumbler-like piece, use a small screw driver or dental tool and push the locking piece in, it's spring loaded. The core can then be removed out the front of the case. BTW, I suggest, if you haven't already, that you removed the glovebox lock case from the door. The Phillips head screw at the back will remove the holder and then you can remove the case. Have fun. Pete
            • Peter L.
              • May 31, 1983
              • 1930
              Re: Glovebox lock
              • Grant M.
                • August 31, 1995
                • 448
                Re: Glovebox lock
                Thanks, Peter!
                grant
                • Grant M.
                  • August 31, 1995
                  • 448
                  Re: Glovebox lock
                  Thanks, Peter!
                  grant
