72 454 POWER STEERING CONVERSION KIT - NCRS Discussion Boards
  • ERIC FAIRCLO
    Did anyone ever try changing from manual steering to a power steering conversion kit like ecklers or vette brakes sell? Would the car be worth less if i change since it is not original? Mine is numbers matching car but has an ecklers front end on it from a small accident from the previous owner. All the mechanics of it are numbers matching. I do have the tank sticker but i can only read the top of it because of deteration. The fram has no rust and is in good shape. Thanks in advance
    • 43221
    Re: 72 454 POWER STEERING CONVERSION KIT
    Eric-----
    If you have an aftermarket front end on the car, I would not worry about the originality consequences of adding power steering. Plus, it's easily reversible if you save the original relay rod.
      • 43221
      Eric-----
