68 Pitman Arm & P/S Valve - NCRS Discussion Boards
  • Dave Kearney
    For the life of me I cannot pop the Power steering valve free from the pitman arm on my '68. I'm using a pickle fork and have even resorted to sliding a steel rod through the engine mount and hamering directly on the castle nut! Any ideas how to get this stubborn thing to seperate? Thanks!
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 68 Pitman Arm & P/S Valve
    I believe you can use a typical ball joint removal tool (such as OTC, etc). They look like a small version of a pitman arm puller, c shaped with flat ears on the end of the C with a threaded shaft in the midde. I always use these instead of picke forks, since they don't damage boots, joints, and allow parts reuse. They are also more effective. Good luck!...Craig
    • Craig S.
      • June 30, 1997
      • 2471
