Oil canister vs spin on - NCRS Discussion Boards
  • steve hess
    What year did the spin on oil filters come into use on Chevys? Was the canister exclusive to Corvettes or was it used on all the engines up to a certain time period?
  • Dave S.
    • August 31, 1992
    • 2927
    Re: Oil canister vs spin on
    The spin on filters started in Corvettes 1968. To the best of my knowledge the passenger cars were the same.
    • Dave S.
      • August 31, 1992
      • 2927
        • 43260
        Dave and Steve----
        Yes, 1968 was the first year for the spin-on filter across all of the Chevrolet car lines. However, some very early 1968 engines may have received the cannister style filter. I don't think that any 1968 Corvettes did, though.
          • 43260
          Dave and Steve----
          • Robert Willis
            The spin on filters were introduced in 68 as a rule but the early Novas (64 to 67 )with the V8 had them. The Nova block was a little different in that the pad for the filter was higher on the block. I think the filter was moved up for clutch linkage clearance.
            • Robert Willis
              • steve hess
                The reason I asked is since my non original motor has the canister I should not assume that is from another Corvette? Sounds like just another mid year Chevy motor, however I get varying answers when I research the motor number. My suffix # on the pad is FO206HC and there is no VIN serial number next to it. The car is a '65, 327/365.
                • steve hess
