I have the clock removed from the dash. Two questions; how do you remove the rear part of the case, and how do you remove the bezel ?
The rear part of the case is crimped (in four places) at the seam where it overlaps the edge of the front part. Is there a trick to "un-crimping" ? My first thought was to wedge a screwdriver blade under the crimp and twist. But that would more than likely severely dent the front half of the case.
In regard to the bezel, I checked the archives and found numerous posts about clocks, but did not find anything specifically about removing the bezel. (I found the ZIP website item about instrument clusters, but it is silent on clocks.)
