Rear shock mounting on Mid Year - NCRS Discussion Boards
  • Rob M.
    • June 30, 1999
    • 171
    I am mounting the rear shocks on my 65 and have "L5" marked upper bolts. My question is the size of the nut. I have a thin nut that is 11/16" across the flats (the bolt head is 5/8" across the flats). Is this the correct nut?
    Rob
    My Project Pictures
    http://temp.corvetteforum.net/classics/l78vetteman/
    • 43221
    Re: Rear shock mounting on Mid Year
    Rob------
    The nut which you describe for the upper shock mount application is EXACTLY the correct nut. Absolutely. Positively.
      • 43221
      Rob------
